engine mount...
Old Aug 1, 2011 | 10:13 PM
jmq24's Avatar
Default engine mount...
so i believe i have a bad engine mount. whenever i stomp the gas and shift into second theres a thud and you can feel it come through the shifter. i climbed under the car, the transmission is firmly in place, that sucker will not budge at all. so all i can think is its the engine mount. is this pretty much it? is replacing it/them straightforward?
edit: also suspecting the u-joints may be the cause
Old Aug 1, 2011 | 10:14 PM
bigj2717's Avatar
Did you check your u-joints?
Old Aug 1, 2011 | 10:20 PM
jmq24's Avatar
no i didnt, i forgot to add that i was also suspecting u-joints, my bad, i need to edit that in
Old Aug 1, 2011 | 10:27 PM
gatorhead's Avatar
I believe it is the tranny mount. It has the weight of the tranny on it so you won't see it. Take a jack and put it under the tranny and gently raise it, you will see it come apart.
Old Aug 1, 2011 | 10:29 PM
jmq24's Avatar
well i had the car on ramps when i tried shifting the tranny, would i still need to use the jack test?
also, excuse my ignorance, but how would i test u-joints?
Old Aug 1, 2011 | 10:34 PM
gatorhead's Avatar
being on the ramps doesn't take any of the weight of the transmission off of the mount. I would say I was 98% sure this was your problem. Go to advance and buy the energy suspension mount for $28.00.
As for checking the u-joints you have to get under the car and move the driveshaft while checking for play. There are several ways to do this and a few are very dangerous. As I said I would put money on it being the tranny mount!
Old Aug 1, 2011 | 10:37 PM
jmq24's Avatar
yeah your more than likely right, i need to go out and buy a jack so i thought the ramps could be a sub for it. im gonna see if i can find some sort of jack and post my findings
Old Aug 1, 2011 | 10:45 PM
gatorhead's Avatar
Wal-Mart has some decent ones now and they are competitively priced Make sure if you out it on the oan you have wood there and go slow and easy
Old Aug 2, 2011 | 09:37 AM
jmq24's Avatar
yes def. i helped my brother with his 5-speed GT a year ago ha, ended up breaking my thumb and dislocating a couple fingers because we were doing it wrong and didnt spend money on the extra jacks like we should have
Old Aug 12, 2011 | 01:42 AM
gatorhead's Avatar
Well what did ya find out?
