Injectors
Old Aug 11, 2011 | 07:22 AM
defaultexistence's Avatar
What year is it? Do u have a service engine light on? This is most likely ignition or sensor related .., how many miles? Have u changed the o2's?
Old Aug 11, 2011 | 11:36 AM
bBody22's Avatar
1994 the engine light **** on then it will go back off it's because the knock sensor is loss and it has been that way for 2 years. and it has round 160,000 miles on it
Old Aug 11, 2011 | 12:05 PM
RamAir95TA's Avatar
If the knock sensor is loose and is rattling that in itself will cause problems due to the PCM retarding timing.
Old Aug 11, 2011 | 03:20 PM
Facepalm...
Old Aug 11, 2011 | 03:58 PM
WS Sick's Avatar
When you say knock sensor are you speaking of the one on the side of the block on the passengers side? Surely by loose you mean wiring or something else, if that sucker was loose youd have a puddle of anti-freeze on the ground.
