th400
Old Aug 14, 2011 | 07:54 PM
95formulalt1350's Avatar
Default th400
can anyone tell me what i need in parts and what all needs to be done to swap from a 4l60e to a th400?
Old Aug 16, 2011 | 11:45 AM
Default ?
any advice or help would greatly help just confused on what i need
Old Aug 16, 2011 | 08:21 PM
cycletech's Avatar
Default th400
gm high tech mag had article installing this tranny into firebird.
Old Aug 17, 2011 | 02:02 AM
Big Al's Avatar
There is a thread here. Do a search.
Al 95 Z28, TH400, S60
Old Aug 17, 2011 | 07:24 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Look over in the transmission section. It's a sticky within the "Stickies are in here!" sticky.
Old Aug 17, 2011 | 10:10 PM
chief455's Avatar
the stickies are helpful
*153 tooth flexplate for 1pc seal with 10.75 bolt circle for torque convertor - be sure to get external or nuetral balance based on your engine
*torque convertor 10.75" bolt circle for th400/th350 chevy - snout will fit the LT1 crank
*th400 short tail (9") from chevy
*dipstick from Lokar/Madman
*trans coolant line adapters to stock lines - or fabricate your own trans cooler lines.
*th400 conversion crossmember (stock 6spd member may work?)
*torque arm mount for th400 - either trans or chassis mounted
*if you want automatic - need vacuum modulator hooked up to intake source
*if you don't - manual valve body
*if you want stock shifter, forward shift - the shifter/cable and trans lever from your 4l60e works, but the cable mount bracket to trans pan will need modified. I had to cut and weld mine to get proper alignment.
* for aftermarket shifter - aftermarket stuff.
*driveshaft - never believe they will fit - you need a th400 trans yoke and must fit the shaft to your car. Maybe you'll get lucky.
*VSS for speedometer/cruise control to work. If you get a later trans from a computer truck / car it might have this, if not you'll need to buy the 40 pulse reluctor, sensor and pigtail. Easy install in trans and hook to your stock 4l60e harness
* PCM - mine did not throw any error codes with the harness left unplugged. Results may vary - you might need trans programmed out of the PCM.
*read the stickies at least 10 times and shop wisely.
Old Aug 18, 2011 | 04:44 PM
David94TA's Avatar
BMR makes a crossmember specifically for this conversion on this page:
http://www.bmrsuspension.com/index.c...d=55&catid=147
Old Aug 19, 2011 | 01:11 AM
the_merv's Avatar
UMI makes one of them Cross Members too..
Old Aug 19, 2011 | 01:34 AM
dtsti's Avatar
I am selling a complete th350 setup that has everything needed.
Old Aug 19, 2011 | 06:55 PM
Big Al's Avatar
My TH400 converter, a small TTI, bolted to the original 4L60E flex plate.
Al 95 Z28, TH400, S60 w/4.30's and a spool
