LT1 malibu a/c questions
Old Aug 23, 2011 | 09:10 PM
natejk's Avatar
Default LT1 malibu a/c questions
looking at an lt1 malibu that does not have a/c but i would like to put a/c in it any info will help thanks
Old Aug 24, 2011 | 06:56 AM
95mysticta's Avatar
You need to post up some pics of your engine compartment to see what you to work with. Cant know unless we see what were looking at. You will likely have to modify the engine compartment to fit an fbody or bbody setup to make it work.
Old Aug 24, 2011 | 07:55 AM
97Z28SS's Avatar
I had an LT1 in an 83 Malibu Wagon and you're going to need an aftermarket accessory drive setup that moves the ac compressor from the stock LT1 location or you'll have to cut the frame. I had the Street & Performance LT1 accessory drive kit but there are cheaper alternatives such as the setup SpeedInc sells.
Old Aug 24, 2011 | 11:25 AM
96TransAmboosted's Avatar
It would be nice to have the year of the car and a little more info. Is it a 66 or 96?
By Brett Foote | 2026-06-04 05:00:17
