LT 1 Guru's please enter
i hope that makes since to you guys i have been working on my car all day so i not thinking straight now lol
The hypertech wont work if the battery is almost dead, or someone might not have returned it back to stock before you bought it. Not sure with the limited info.
As for the programmer is it fully plugged into the ALDL?
Are any lights coming on the programmer? If not check the fuse for the aldl to make sure its not blown. A Coil could even be bad. Not to mention the fuel pump could be insufficient. You either need some help with diag or take it to a good shop.
Where is the fuse @ for the ALDL? is it under the hood or on the side of the dash. the status light blinks on and off and when i hold the power button it lights up but when i let go of the button it goes off
