Getting a Miss Under a Load
Old Aug 29, 2011 | 09:22 PM
Wicked94z28's Avatar
Default Getting a Miss Under a Load
when Im under a load I have a miss , its not horrible but its still killing me.... I just put a new set of ngk irridiums in it, wires have about 800miles on them and are 10.2's, still have it.... a couple days ago we but some "blueberry burnout" fuel additive in it but i ran that gas out , threw 10 in, ran that out, put 10 more in, and ran that out and just put 20 in the tank and its still going on...... opti is gm performance that I just replaced about 200miles ago... any ideas?
Old Aug 29, 2011 | 09:24 PM
defaultexistence's Avatar
Plugs or their gap what is gap?
Old Aug 29, 2011 | 09:27 PM
i left them alone at 50
Old Aug 29, 2011 | 11:18 PM
Should I gap them different?
Old Aug 30, 2011 | 02:16 AM
FormulaJoe's Avatar
I'm dealing with a similar problem. The book says 45, right? I'm thinking I just need a tune..
Old Aug 30, 2011 | 02:43 AM
96LT1355Z28's Avatar
Wicked, if you sig is accurate you might try gapping them a little tighter, when my gap was to big it would idle and drive in town fine but under WOT it would cut out and miss above 3000 rpm. I'm using Autolite 104's @ .030 now.
Old Aug 30, 2011 | 10:15 AM
96 that's about exactly what mines doing.... gonna go pull them and knock em down to 30 and ill.let ya know how it goes!
Old Aug 30, 2011 | 10:31 AM
jaycenk's Avatar
What do the old plugs look like?
Old Aug 30, 2011 | 10:44 AM
RamAir95TA's Avatar
Likely an ignition issue. Cylinder pressures are higher under load which can blow out spark if the gap is too large or too weak.
Old Aug 30, 2011 | 03:28 PM
That was the problem, gapped em at 30 and.now.she's running like she should....now time to break this Detroit locker launching tomarow night lol
Old Aug 30, 2011 | 03:58 PM
ehhhhpp!
Old Aug 30, 2011 | 08:39 PM
nascarnate326's Avatar
I would guess ignition as well.
MAF, o2 sensor, plugs, wires, opti, idk what else it could be.
I did plugs, wires, opti, and MAF all at once.
Old Aug 30, 2011 | 08:44 PM
wrd1972's Avatar
Check for above normal resistance on the plug wires. I had small misfires due to the helical conductor being broken at the terminal on my MSD wires. Repaired the wires and all had acceptable resistance.
Old Aug 30, 2011 | 09:39 PM
Lol !
Old Aug 30, 2011 | 09:40 PM
RamAir95TA's Avatar
Apparently everyone missed the point where he mentioned he fixed his problem...
Old Aug 31, 2011 | 01:27 AM
ls2pontiac's Avatar
Self-Admitted Scammer
You need to convert to the EFI 24x system, screw the damn opti
Old Sep 1, 2011 | 09:55 AM
Love the opti.....I'm.at the.point.with the opti where.I have a.lifetime.warranty and.got.so.good.at.swapping.them it.takes.less.then a hour for a.swap.and back on.the road!
Old Sep 1, 2011 | 03:30 PM
jaycenk's Avatar
It's your blinker fluid level...you over filled it.
Good to know about the plug gap. I had no idea it would blow it out. lert me sumtin new today boss.
Old Sep 1, 2011 | 07:52 PM
Same here.... I could have almost garaunteed it.woulda been the refoobulator switch on my dome light but I was.wrong.....
Old Sep 1, 2011 | 08:42 PM
All you's guy's had ta do was axe!
