Pick some pushrods for me.
Old Aug 30, 2011 | 06:16 PM
Rob94hawk's Avatar
Default Pick some pushrods for me.
I'm fed up with researching. As far as I can tell this is the last part that I need to finish the engine.
Stuff I have already:
Cam specs: 232/240 .595/.595 110 LSA (installed)
New LS7 lifters
5/16" Trick Flow guideplates
1.6" COMP Cams Ultra Pro Magnum Rockers
Pushrod length needed: 7.15
I trust your judgement, most of you anyway...Pick a pushrod for me please. Gonna order it tonight. Thanx
Old Aug 30, 2011 | 06:20 PM
gregrob's Avatar
You CAN NOT know what length you need without measuring! That jas been said hundreds of times on here.
If the heads have never been off the car, use stock 7.2, otherwise its a WAG
Old Aug 30, 2011 | 06:22 PM
pillarpod's Avatar
i'm runing Comps on mine
Old Aug 30, 2011 | 06:24 PM
Rob94hawk's Avatar
Maybe I should clarify what I meant.
Brand name: Trick Flow, Comp Cams, Isky, etc. Not length. I got the length already.
Oh, and another thing, help the clueless out here, if I'm running 5/16" guideplates as stated above, what DIAMETER pushrods to I need?
Old Aug 30, 2011 | 06:40 PM
96TransAmboosted's Avatar
Chromoly 1 piece comp.
If heads are off measure
Old Aug 30, 2011 | 08:51 PM
gregrob's Avatar
Trick flow .080 wall chromoly works well on a mild setup. I used mantons 5/16 .118 wall in my build
Old Aug 30, 2011 | 09:14 PM
joelster's Avatar
See if Summit has anything in stock for that length, if not call Manton or Trend. I ordered my custom pushrods through Trend and couldn't be happier. They were 3/8's that tapered down to 5/16's ball end, .080" chromoly in 7.8" length and they were $170ish ($10 and change apiece). Built to order arrived in 3 days. Most weird lengths will be out of stock at Summit.
Old Aug 31, 2011 | 04:14 AM
95LTXZ28's Avatar
I am running comp hi-techs and have no issues with them.
Old Aug 31, 2011 | 05:55 AM
lsxc4vette's Avatar
I agree
