24x coil selection
Stock LS1 wires will not fit.
BizZzatch, nice copy cat work! Thanks for the compliments on my wire setup. It definitely turned out better than I thought.
-Stay away from LS1/6 coils. They work but are the weakest of the bunch.
-While any LS2/3/4/7 LQ4/9 etc coil work, the round heat-sinked truck coils are the best.
-LS1/6 coil coils and wiring harnesses have a different pin-out at the coil plugs than all the others.
-Every different style of coil has it's own coil bracket. Don't think any bracket will work with any coil.
-The best spark plug wires to use is the Granatelli Motorsports zero ohm wires.
-The round heat-sinked coils have special dwell abilities that allow you to really take advantage of their output and need to be tuned appropriately.
If you want to go this route you could of course cut the rod stock down so its not sticking up, wasn't worth my time I guess.
It's sorta ugly, but it works.
Really, not a bad setup. Just beware of vibrations and those coils coming loose. Vibration will kill 'em.
This is a really great idea. The only difference I would make to make it look "sexy"
, is to cut the studs down a bit and use the chrome acorn type cover nuts, like these:http://www.ebay.com/itm/Chrome-Acorn...-/220672664590And you could always sand them and paint them, depending on the look you're going for.
