smaller fresh air adapter?
Old Sep 10, 2011 | 09:28 PM
Dave357LT1's Avatar
Default smaller fresh air adapter?
Im trying to hookup my oil catch can from the fresh air tube off the pass. Side (stock) valve cover. The tube on there is much larger than what the can needs. Is there a replacement bung that fits in the stock hole with a hookup for a smaller tube?
Old Sep 11, 2011 | 11:05 AM
Low N Slow's Avatar
Wrong place for a catch can, most of the time the airflow will be trying to go backwards through the catch can, the can should go on the other side in line with the pcv valve.
Old Sep 11, 2011 | 11:42 AM
Dave357LT1's Avatar
I have a asm monoblade t.b. that does not have a port for the fresh air hose. Im gonna have to vent the fresh air tube to another vac port on the intake and if there is any blowby i didnt want it going into the intake. So ur saying there is more vac under the valve cover than in the intake? I could be wrong but dosnt sound right...
Old Sep 14, 2011 | 11:27 PM
Formula413's Avatar
What Low N Slow said is correct, the catch can belongs in the PCV line. Best thing to do for the line coming out of the pass side valve cover is to replace the little plastic elbow with a breather filter, works great for keeping oil out of that line.
Old Sep 15, 2011 | 05:38 AM
RamAir95TA's Avatar
Ideally you want a catch can on both of those lines.
