LTCC spark plug wire selection, will these be OK?
Old Sep 13, 2011 | 08:14 PM
GR33N GoblinM6's Avatar
Default LTCC spark plug wire selection, will these be OK?
I am about to do my LTCC conversion since my kit came in yesterday.
I was about to buy some Universal Taylor Pro wires, 8mm.. when i realized that i have a set of Universal Accel super stock, radio suppression, 8mm cut to fit wire set.. the part # is 4041. found here http://www.summitracing.com/parts/ACC-4041/
I know i need to order some new ends that will slip over the LS1 coil pack, but will these wires be OK to use?
also are these the coil ends to use? tay-46066
thanks
Old Sep 13, 2011 | 11:51 PM
No one knows?
Old Sep 14, 2011 | 05:31 AM
RamAir95TA's Avatar
The plug wires still carry the same spark, so I'm sure they will work just fine. Just make sure your connections are solid and that you use some dielectric grease on the boots to keep them insulated.
Old Sep 14, 2011 | 06:43 AM
Paul Bell's Avatar
That's MISTER MODERATOR
What he said^
Just stay away from Taylor wires.
