Clutch dragging?
I ended up swapping in a bushing afterwords, put a small dab of grease on the inside of it and that made the inputshaft slide right in.
Next time you put the trans in, I would suggest using a jack that can hold the trans securely in place. Perhaps strap it down to your jack. You want the trans to slide all the way up to the bellhousing. Take your time and don't force anything. It should slide all the way to the bellhousing with very little effort once everything is lined up.
Thank you all for the help!
The only way I was able to tell something was wrong inside was when I'd have the clutch pushed in at idle (pilot bearing is spinning). I'd feel some very faint vibration in the pedal.
If the car was in gear and already moving, everything felt normal because the clutch was engaged (meaning the engine and input shaft are locked together, spinning at the same rate, and because of this the pilot bearing is still).
I forgot to mention that previous to my clutch install, the original? pilot BEARING was fubar. I didn't even think to see if it damaged the input shaft.
How was the bearing fubar? Missing bearings?
