Street Motor LT1
4 bolt splayed
Wiesco pro tru pistons
6" H beam rods
H series bearings
Arp studs/bolts
LKN speed heads decked .040
Lloyd Elliot 58mm intake
Canton pan
Ford racing 39 lb injectors
1.6 comp roller rockers
Beehive springs
Long tubes
Spec 4 clutch
Deleted a/c and abs
236/242-112 sb circle cam
CSR electric water pump
Double roller timing set
Msd opti
SLP exahust
Full tank of 100 octane lol
Let me know what I missed
Thanks guys
What specs do you need to dial inthe compression? Maybe we can figure it out.
Thanks
http://www.turbofast.com.au/Tfcomp.html
It's been heat cycled and the 2nd oil change as been done but is it too soon for the dyno session on Monday? I forgot to ask Brain from Kaltech about this.
BTW, awesome dyno spilner!
