harness??
Old Oct 4, 2011 | 09:42 AM
andrew ws6's Avatar
Default harness??
I have a 95 T/A that a got without engine tranny and harness, what year harnesses will interchange, I still have the wires to the car and would like for my dash gauges to work. I am going with a th350 for trans.
Old Oct 4, 2011 | 11:18 AM
merim123's Avatar
shbox site is your friend on this one. you'll have to do some research and compare. the biggest connectors to pay attention to are the c100, c200 (210,220,230)
Old Oct 4, 2011 | 12:26 PM
shbox's Avatar
A 95 harness is the only one that will be an exact match. There are slight differences to 94 and 96-7.
Old Oct 4, 2011 | 04:44 PM
andrew ws6's Avatar
Thanks for the info
Old Oct 4, 2011 | 05:13 PM
madhatter's Avatar
Hey Rob can you elaborate on that? I am getting ready to repin a harness from a 94 for my 24x setup. As far as I knew they were the same.
Old Oct 4, 2011 | 06:29 PM
merim123's Avatar
they are different. I repinned my 96 harness into a 94. Use the site and check the connectors I said above, will tell you all. Don't forget the 94 didn't have the crank position sensor
Old Oct 4, 2011 | 08:05 PM
6.3L_LT1's Avatar
The 1995 LT1 harness is unique however you can convert a 1994 if you can read a schematic and re-route and re-terminate a few of wires. I buaght a 1994 harness advertised as 1994 and 1995. I had rewire it, grafted in a C1o5 connector and ohmed it all out just fine.
The connectors, wire colors and pin-out is identicle at the PCM.
I wish I could remember all the details and help further but if you go to.shbox site and look through the electrical section you can find everything you need. Please support the site while you are there, it is operated on donations and it is a blessing for 1995 F-bodies (and some info for 1993/94 and 1996/97).
http://shbox.com/1/schematics_wiring.html
Good Luck
Old Oct 4, 2011 | 08:10 PM
andrew ws6's Avatar
Another question, if I buy a computer harness and engine will it work with the body harness from the 95 sorry if its already been answered but wiring is my downfall
Old Oct 4, 2011 | 08:27 PM
6.3L_LT1's Avatar
The engine harness connects at the P/S shock tower with connectors C100 and C105 and in the passanger compartment (under the dash behing the P/S trim panel) through connectors C210, C220, and C230 (the ac connects there also). Other than that the body and dash horness are indepenent of the PCM.
That's all I know.
Old Oct 4, 2011 | 09:25 PM
merim123's Avatar
94's only had the c100, the c105 came on 95+
Old Oct 4, 2011 | 09:32 PM
shbox's Avatar
As already suggested, use my site to check connector differences. That is why it is there (so I don't have to "elaborate" the same info all the time ).
