LT1 runs then dies
Old Oct 4, 2011 | 01:22 PM
5150wheeler's Avatar
Default LT1 runs then dies
I have a 94 LT1 from a camaro that is in a rockcrawler. I rolled the rockcrawler and when I restarted it post roll it was difficult to start and idled rough. I got it home and took apart the intake. I cleaned all of the oil and dirt from all of the sensors. Now when I turn it over it fires instantly but then dies. I can keep it running if I play with the throttle. I have swapped out the IAS, the MAFs, and the TPS.
Note: the motor will run if I disconect the MAF but runs at high idle.
Pls help?
Old Oct 4, 2011 | 01:40 PM
jlpz's Avatar
Have you checked the fuel pressure?
Old Oct 4, 2011 | 02:47 PM
fuel pressure is fine.
Old Oct 4, 2011 | 03:54 PM
it was a vacume leak between the throttle body and the intake. thanks for the help.
