Coolant "filter"? (Don't use Blue Devil)
-In May my 95 Formula blew a headgasket
-I was far from home so I walked to an autoparts store and got "Blue Devil" head gasket sealer and put it in.
-The "Blue Devil" worked well enough to serve as a "bandaid" to get it home.
-I finally got the car back together/running yesterday after replacing headgaskets
Today:
What I am running in to now is that Blue Devil sealer crap clogging up my coolant system. I've had the coolant flushed out twice and they have been getting a lot of "chunks" of this crap out of everywhere, but there still must be more. I decided to drive the car a few days to see if it doesn't "loosen" up more of this crap and I will probably flush the system again tomorrow.
Symptoms:
-Luke warm dash vent air on "heat"-(NOW FIXED)
-Warmer than usual engine temps
-When opening bleeder screws, it immediately squirts coolant, so I am pretty convinced there is no air pockets.
Question/Idea:
I was wondering if there was any reason why I couldn't remove the thermostat for a few days and put a metal mesh screen in there to help "filter out" the coolant?
Just an idea that came to my head, and thought I'd ask about it. Does anyone else have experience with stuff like this? I hope this isn't going to be a nightmare, Im ready to just enjoy the car again finally!
Thanks in advance for any advice, and for those of you who haven't used "Blue Devil"-DON'T! Save the money, hassle, and mess, and call a tow truck!
same with radiator and heater core lines... flush one direction then the other, just be weary of how much pressure you put on the heater core as they have busted before.
Any type of "pour in" sealer works by clogging up the small openings.
Off the top of my head, this would leave the
a). steam pipe,
b). radiator,
c). block, and
d). heads, correct?
I assume its not the radiator because it's been flushed out like 5 times now. The heads and block were cleaned when the motor was taken apart, so Im thinking those are less probable as well.
This is what the car is doing now:
It's fine at idle, but as soon as you give it any throttle, you can see the temp climb. Would it make sense that the steam pipe is clogged? (The heads can't "vent" when they build heat?)
I'd just buy an oil filter relocation kit, and plum it in to a heater hose. Then find a coolant filter that will fit the thread. A kit for a PH8A would have the most common thread.
Al 95 Z28
