Lt1 is out of action again
Old Oct 19, 2011 | 11:26 PM
will1380's Avatar
Default Lt1 is out of action again
Well I finally got her running right after clutch going out and burning up plug wires and now this happens.
I was driving home from work and i noticed sometimes when I pushed the clutch pedal in to shift and let go of the pedal it felt like the pedal was kinda stuck and slowly came back up. Came to a stop light put her in first and tried to go and it died. After three tries finally got it in gear. As I was slowing to turn into my neighborhood I had it in second and clutch pedal all the way in and the car was starting to go into second gear without releasing the pedal.
I replaced the slave cylinder with and that didn't work. Does the master cylinder play a part in the clutch pedal pressure? I'm starting to get upset with all the problems I've been running in to.
Old Oct 20, 2011 | 07:34 AM
Ocala93TA's Avatar
You didnt replace everything as one unit ? If you just did the slave i would make sure its completely bleed of air as far as the master if theres a leak in the feed line it could let air back in the slave which could cause a problem but as far as pressure i dont think it has anything to do with it .
Old Oct 20, 2011 | 02:47 PM
merim123's Avatar
i just went through this myself, my problem was opposite. I had a extremely hard pedal that just did not want to go down. I ended up replacing the whole setup and got myself up and running. You can buy a completely bled setup for 175 or so.
