Help
Old Oct 30, 2011 | 05:17 PM
Z28animal's Avatar
Default Help
I have a 95 z28! I changed fuel reley, ignition coil, fuel filter, and bypassed the vats system and car is still shutting off while driving! Seem like when I'm under acceleration! It will die then when I try to start it it won't start then I'll wait about 5 min and it will run! It has spark and fuel pressure! I'm goin crazy can't find out whTs wrong! Any help will be appreciated!
Old Oct 30, 2011 | 05:36 PM
vtec's Avatar
Resident Racing Jerk
check grounds then replace ignition switch.
Old Oct 30, 2011 | 07:38 PM
Z28animal's Avatar
Ware would be a good place to start checking grounds??
Old Oct 30, 2011 | 07:39 PM
Z28animal's Avatar
Also is the ignition switch hard to change and is it expensive
