firing issues
Old Oct 30, 2011 | 07:38 PM
slogo1's Avatar
Default firing issues
i've asked for help with it before, still haven't had any luck. should the coil still fire if the optispark is bad?
Old Oct 30, 2011 | 10:47 PM
jaycenk's Avatar
optical sensor can be good and cause the coil to fire when it is supposed to but if the rotor or cap of the opti have a problem then the spark wont reach the correct plug wire post on the opti. Is that what you are asking? You didn't realy provide much info there.
