LT4 Knock module or OBD2 knock sensor?
Old Nov 2, 2011 | 08:13 PM
camaro350's Avatar
Default LT4 Knock module or OBD2 knock sensor?
I am installing an lt4 Hot cam with Lt4 spring set and 1.6 Crane Gold RR's in a 95 Z28 and i have read some post that to desensatize knock i can use an OBD2 Knock sensor like form a 96 Z, is this true or do i get myself a lt4 module. Please help.
Old Nov 2, 2011 | 09:50 PM
shbox's Avatar
Since you have a 1995, which is OBD-I (assuming you still are using the stock computer), you can't use an OBD-II KS. You can use the LT4 KM, though.
Old Nov 3, 2011 | 05:34 AM
RamAir95TA's Avatar
The first thing to do is determine whether or not your knock is real or false.
