o2 Simulator's or Extensions
Old Nov 4, 2011 | 10:43 AM
blakez28's Avatar
Default o2 Simulator's or Extensions
I'm headed home for some much needed leave, to wrap up some issues with the camaro. I started a longtube header install, and didn't finish it while I was home a few months ago. We got the stock manifolds off before we called it quits, and it's been sitting for a while. I'm running ebay longtubes, and also replacing the plugs/wires while I'm under there. I'm just making sure I have all my bases covered before this veterans day holiday.
1) Where should I get an extension for the front o's?
2) I have to run front o2's correct?
3) Will the steering knuckle have to be moved/ how do you disconnect the steering knuckle?
4) What problems should I run into if any?
Felpro 1406's and new header bolts already waiting for me back in SC.
Also a picture of my buddies new 5.0. Guess who's tranny broke at <3000 miles lol. and guess how much Ford warrantied due to "driver error"
Old Nov 4, 2011 | 10:49 AM
02v8ta's Avatar
Glad you'll be back !
1. Got mine from ws6store.com but summit and jegs have them too.
2. Yes
3. Depends on the headers. I didn't.
Old Nov 4, 2011 | 05:50 PM
blakez28's Avatar
2. Yes
Part O2EXT12 at ws6store?
Old Nov 4, 2011 | 06:01 PM
lt1slowz28's Avatar
I think I got the 18's and it ended up being too long... good luck with the headers, I would rather drop the k member next time and do it that way... honestly is easier.
Old Nov 4, 2011 | 08:55 PM
blakez28's Avatar
I'm running a pa k member with solid motor mounts so I'd rather not go through that again.
Anyone have a def. part number for the extensions? I'm pretty sure it has to be a two prong correct?
Old Nov 4, 2011 | 11:05 PM
lt1slowz28's Avatar
depends on what style your car has... just look, or have someone check it out?
but for mine I had the flat connectors, yours could be square.
http://www.ws6project.com/user_stor/...lat-extension/
Old Nov 4, 2011 | 11:38 PM
blakez28's Avatar
I have a 95 Camaro. Aren't they all the same style?
Old Nov 5, 2011 | 12:38 AM
lt1slowz28's Avatar
I've heard of some being mixed, chances are yours are the flat style if you have obdI.
Old Nov 5, 2011 | 12:52 AM
02v8ta's Avatar
My bet would be they are the flat style as well. The rear ones aren't though so make sure you check the front.
I can't bring up the part # I got now but if anything ws6store customer service, even via email is excellent if you just want to tell them what year car you need them for. Also 1 of the 2 18" extensions is super long as someone said. I don't mind having a zip tie under my car
Old Nov 5, 2011 | 05:00 PM
blakez28's Avatar
I planned on just using zip ties for the excess as well. Doesn't bother me at all.
Also I plan on just deleting the rear o2. Should that be a problem even after I get the car tuned? I don't have a cat anyways.
Old Nov 5, 2011 | 05:16 PM
lt1slowz28's Avatar
are you OBDI or OBDII... kind of makes a difference, as well as with OBDI you will not have rear o2's.
Old Nov 5, 2011 | 05:39 PM
blakez28's Avatar
OBDI
Again aren't all 95's OBDI with OBDII connectors?
Old Nov 5, 2011 | 05:44 PM
lt1slowz28's Avatar
in the car yes... OBDII connection inside, but... everything else(i.e. 02's and crank sensor, rather lack thereof) is OBDI .
Old Nov 5, 2011 | 05:45 PM
gregrob's Avatar
Yes all 95s are OBD I with an OBD II DLC.
All the LT1 equipped cars I have seen use the same flat 4 pin 02 connector rso no it doesn't matter what year you are, other than 96-97 will have rear 02s which can be tuned out, and you need a tune with headers.
Old Nov 5, 2011 | 05:48 PM
blakez28's Avatar
I tried to scan my car a few years ago, and learned that they were OBDI with OBDII connectors. pain in the *** for someone that doesn't know.
I also just ordered the o2 extensions so thanks for your help
Old Nov 5, 2011 | 06:03 PM
blakez28's Avatar
I'm going to get her tuned anyways before I spray again, but I'll do a bolt-on tune while I'm at it. Might be a little while, but I'll post the results. Thanks for the insight
