Summit Roller Rocker Difference
Im looking into budget roller rockers. Id rather not buy used parts so Im looking at cheaper new ones. Summit has two different house brand Roller Rockers that are about a $30 difference. Can anyone tell me what makes the blue ones worth the extra cash?
http://www.summitracing.com/compare.aspx
Also has anyone heard of the Angus Brand Roller Rockers that Skip White sells? They are made in the USA for around $150 shipped. I saw he has the Wysco ones on there for 113 but Im scared of chinese engine parts.
I will be running a pretty mild cam with the stock heads. Im leaning toward the Lunati 60121 or cc503. Probably whichever I can find cheaper.
Thanks
Well the waterpump is starting to leak and I need to change the opti. Its also leaking oil from the rear of the intake and the timing cover. By the time I tear it down that far I might as well slide a cam in it.
My 355 build is going to be well over $5000 dollars. I was hoping to have it done within a year but thats just not going to happen. Im looking at two years. Theres really no point in building it and putting wasted miles on it with the stock heads. I want to hit maybe 340rwhp with this engine and see if I can hit low twelves with it. And when I finally get the new motor together I can give this one to my brother to play with.
As for the cam, id go with the cc503 over the lunati 60121. Have you considered the 60122?? I was considering that cam and its more similar to the cc503 than the 60121. The 60121 is more similar to the hot cam and might leave you wanting more in the lope department.
Part numbers- SUM-G6906 Slot width-0.730 in.
and
SUM-G6920B Slot Width-0.634 in.
The only difference I saw was the slot width. What exactly is the slot width?
AHRITCHIE, let me know on that cam.
hth
andy schuck
Let us know how that voodoo 60122 works out for you, i was thinking of using that on a future 355.
And I believe the Lunati 60122 will be too big for what Im doing. I dont think it would work well with my stock 342 gear and stock heads/bottom end. I like the 60121 because its like a more aggresive hotcam. I loved the hotcam in my last car.
