Start of a budget build with used parts.
Next was the assembly of the rockers. These have been laying around the garage for a while now. It's good to finally use them.
These should keep my valvetrain rock solid during any anticipated high RPM blasts. Non-self aligning and no guideplates. Guideplates.....we dont need no stinking guideplates.:woohoo:
Who's are they and what ratio?
LOL, No not showing off. Just being ornery.
They're really just some old used stuff I had laying around. They're Jesel 1.6 ratio. The solid roller cam is fairly small. .390 lobe lift on the intake and .400 exhaust. Probably around 625/640 valve lift minus the .016 lash.
They're really just some old used stuff I had laying around. They're Jesel 1.6 ratio. The solid roller cam is fairly small. .390 lobe lift on the intake and .400 exhaust. Probably around 625/640 valve lift minus the .016 lash. Didn't get much done today except a lot of cleaning for the next stage of the assembly. I started assembling the "roll your own" plug wires. They're Taylor spiro-pros and I've had great luck with them in the past so why change? I wanted to at least get the header up there to check the clearance to the plug wires. Everything appears to be good. Now just get off my dead butt and do it.
I dug into my used parts and found two water pumps. Both are fo an Impala and I don't know if they'll work on the Vette. They looked real close but it'll take more checking before I bolt it up. I want to put the Meziere on the shiny powder coated pump.
Plug clearance is OK around the headers. #2 is about 1" away but the Taylor wires have some great high temp silicone ends on them. I've been closer on the Impala with no problems.
I'm going to have to get 45 degree plug boots for the coil packs. I don't like the wires laying on top of the valve cover.
Time to hit the classifieds and find more stuff. I'm running out. This build and the Impala build have depleted my supply of junk.
I bet you have a built trans "lying" around to, huh? lol
I've got a guy in Oklahoma holding a Dana 44 for me. I'll go pick it up when I get my truck running. I don't expect my 7 1/2" Dana 33 will work very long. I got the 9 1/2" converter from Lawhead here on the forum. Ya' gotta love used parts and leftovers.
All those used parts look pretty worn out and probably wont hold up. I could come and get them out of your way for free because that's the kind of guy I am, just want to help out. It would made the miss' happy too.
She took my "man-cave".
Besides, I read your sig:
Best 1/4 11.63 @ 116.42 1.55 60ft 3700lbs.
I'm going to try to catch you with the old 3400# Vette.
Whats next? Is a magical fairy gunna drop off a built 4L60 and a 12 bolt?
No, I'm going to rebuild my tranny when I pull the engine. Parts are here in a box or two. A Corvette Forum member is selling me a Dana 44 for $400.00. I'm taking a road trip to Colorado to pick it up when I get my truck fixed. Gotta put a junkyard rear in it.Here's an earlier post where I mentioned that. The 3800 came from a forum member.
I wish. I have a big box of parts that will fit inside mine when I pull the engine and transmission to do the swap. It will take me a couple of days to rebuild it. I do have a 3800 stall converter just laying around.....as a matter of fact it's in my computer room. That would be it by the headers.
