96 z28 engine swap ?
94 = OBD1
96 = OBD2
Cam, timing cover, opti etc must be switched over from old motor. also depending on if its a early 94 motor oil pressure sensor might be on the drivers side of the block above the oil filter instead of on the back of the intake, 96 wiring harness might not reach.
