Fitting size?
Old Nov 16, 2011 | 11:32 AM
MAROBOY_TRAV's Avatar
Default Fitting size?
What size is the male end that is going into the brass fitting On the transmission..??
Looks like it can be a 1/4 compression thread..
Old Nov 16, 2011 | 11:54 AM
The pic is from a 4l60e trans off a 94LT1
Old Nov 16, 2011 | 01:44 PM
1badzee's Avatar
I did 1/4" to a pushloc fitting (-06 equivalent I believe) on my TH350 using a pushloc hose all the way to a cooler. Are you using the stock lines?
Old Nov 16, 2011 | 08:53 PM
Yes I bought a 8ft stock line from so im going to cut it and run2 4ft lines 2 my existing lines coming from the radiator.. So nowi need the 2 male ends now..
