Belt Size
Old Nov 17, 2011 | 08:56 PM
fastredlt1's Avatar
Default Belt Size
I put a GM AC delete pulley on my 97 TA. I have been told i can use the stock belt but its way to big. Has or does anyone no of a different belt to use???
Old Nov 17, 2011 | 09:03 PM
lt1slowz28's Avatar
I used a GM 1le pulley as well, make sure the belt is routed properly as it will be the stock length.
Old Nov 17, 2011 | 10:02 PM
fastredlt1's Avatar
Default Belt size
Everything is on right, belt is just way to big. I can push on the belt by the alternator and it will hit the power steering pulling.
Old Nov 17, 2011 | 10:08 PM
shbox's Avatar
You might try a 635 (last three digits of belt number) belt. They used two different a/c pulley sizes over the years, but it seem only one size of delete pulley. So, some people end up needing a slightly different size belt.
Old Nov 18, 2011 | 05:15 AM
RamAir95TA's Avatar
Use a cloth tape measure or a piece of string. Route it through the pulleys then measure its overall length. Go to the parts store and buy a few different size belts. Find one that fits, then return the others.
That's what I did with my non-GM pulley.
Old Nov 23, 2011 | 06:32 PM
Low N Slow's Avatar
This is the belt I had to use on mine.
