Ebay fabbed valve covers?
Old Dec 9, 2011 | 08:22 AM
ahritchie's Avatar
Question Ebay fabbed valve covers?
So I was looking on flea bay at valve covers and I came across these nice looking fabbed valve covers almost identical to the Canton ones which are double the price. Any body running these? Any leaks or fitment issues?
NON-SPONSOR.com.org.gov.net
I asked the seller if they make a F-body version with the alternator notch built in....THEY DO! They just aren't listed....$99.95. Seems like a good deal but I want to find out if anybody has had any problems first.
Old Dec 9, 2011 | 09:21 AM
z28_theantirice's Avatar
I've been tempted, but some stay they are a bi%&H to get to seal.
Old Dec 9, 2011 | 09:24 AM
BOBS99SS's Avatar
Captain Double Post
^this, i was going to order there ls style but i heard way to many people having issues with leaks and crap,they look nice though
Old Dec 9, 2011 | 11:53 AM
93QWKZEE's Avatar
These are the exact same version i have.I have zero leaks at all. As long as you know how to install valve cover gaskets you should be fine. Also on a side note i had cantons before these and have heard of sealing issues with those as well and i had zero issues with them. Just keep in mind you need to have an oil cap tig welded on or some other type of push-in oil fill cap. And pcv if you have it still. I do not!
Old Dec 9, 2011 | 12:33 PM
jlpz's Avatar
do they have a notch for the ALT..or did you modify yours?? want to know I'm willing to take a 84 dollar risk..
Old Dec 9, 2011 | 12:43 PM
ahritchie's Avatar
Damn...just noticed your right...no oil cap hole; that sucks, guess that's why the cantons cost more. I have no idea how much it costs to get something like that welded, seems like a pain in the ***. Guess I'm gonna stick with my ugly *** stock ones for sleeper "stock" look Over $200 seems a bit much for some valve covers. I had the other cheap polished chrome looking ebay valve covers, but they look like *** now and the rockers are hitting them. Does nobody sell a decent set of TALL valve covers for less than the cantons (with the alternator notch)?
Dude...re-read my original post...like I said, this shop sells them with the notch already made....it's $15 extra....$99.95. This is coming straight from the seller. They do not have those listed on ebay however.
Old Dec 9, 2011 | 01:04 PM
ahritchie's Avatar
Originally Posted by DVS LT1
I think I paid $75 and the guys at my shop sent the passenger side cover out to get modified (cut & re-welded) to fit the alternator, and to add two holes one for a valve breather and another for an oil cap. If they now sell ones notched (enough) for clear the alternator then having someone punch out and fit a valve breather shouldn't be too much.
Good to hear from somebody with firsthand experience...how much did it cost to get the holes added for a oil cap/valve breather? I also just sent them a message on ebay asking if they can make a version with the holes already added; never hurts to ask.
FYI...The seller just replied about the holes: "I cant do it here, but you could have it done once you got it. We have just had too many issues in the past where people werenot satisfied the placement..etc."
I guess I could call a couple machine shops and see what they say as far as cost on this.
Old Dec 9, 2011 | 01:36 PM
93QWKZEE's Avatar
^this is the reason i got these covers so i can place everything where i liked it. I got -AN weld on bungs for a catch can setup and a weld on oil cap and just drilled the holes out myself. I have a friend that tig welds so im not sure how much that would cost for you. And I dont have them notched because i have the speedinc kit.
Old Dec 9, 2011 | 01:44 PM
defaultexistence's Avatar
A push in rubber oil cap and a properly sized holesaw will work without the need for a machinist ..
Old Dec 9, 2011 | 02:19 PM
LVZ2881's Avatar
Somebody here on tech pointed these out me. not sure if these are from the same seller, but they look good and have the caps and holes already drilled. I was gonna order them here next month.
http://www.abad71camaro.com/servlet/...t-Valve/Detail
Old Dec 9, 2011 | 02:40 PM
ahritchie's Avatar
Those are like the set I had....unfortunately, they are the short valve covers; maybe my rockers are bigger than most (comp cams pro magnums?) because they were hitting the top of the valve cover; which is odd because they don't on the stock ones Looks like the only "tall" valve covers are these and the cantons....correct me if wrong.
Old Dec 9, 2011 | 07:29 PM
RGSS's Avatar
I ran those for a while.
They sealed great.
Old Dec 10, 2011 | 05:11 PM
95sscamaro's Avatar
This is what i run, with only small cutting on the alternator
Uploaded with ImageShack.us
Old Dec 11, 2011 | 08:33 PM
95_TA_USMC's Avatar
i gotta set of the tall fabbed ones from ebay and they are great, look and seal great too! couldn't be happier!
Old Dec 11, 2011 | 09:03 PM
coolmanvette75's Avatar
Can someone post a link up here? Dont think it should be a problem since its ebay
