So I was doing a routine rear end fluid change and found this
Old Dec 14, 2011 | 07:28 AM
quik95lt1's Avatar
ahhhhhhhh theres nothing wrong with that you still got some left........put it back in!!!!
Old Dec 15, 2011 | 01:17 AM
93Z2871805's Avatar
Veteran: Air Force
Lol, it's not bad until it's completely round right?
Old Dec 15, 2011 | 01:37 AM
Tinbender59's Avatar
Originally Posted by Rob94hawk
Looks fine to me. Put it back.
now that is funny I don't care who you are LOL
Old Dec 15, 2011 | 05:01 AM
BOBS99SS's Avatar
Captain Double Post
10 bolt wins again lol,
Old Dec 15, 2011 | 05:54 AM
Rob94hawk's Avatar
Originally Posted by speed_demon24
Now that I think about it this is kind of scary considering I pretty much have a similiar setup as you. Were you using drag radials at all? If so I think I'll be skipping them entirely till I get a stronger rear...
Old Dec 15, 2011 | 06:59 AM
pillarpod's Avatar
bump it up, you know want 4.10 now
Old Dec 15, 2011 | 07:36 AM
quik95lt1's Avatar
yea actually thats even better if he grinds ALL the teeth off it will be perfectly balanced again and will run even smoother........
Old Dec 15, 2011 | 11:03 AM
93Z2871805's Avatar
Veteran: Air Force
So that's your secret to running 9.9s @ 134.8 N/A... I'm heading out to the garage to start grinding...lol
Old Dec 15, 2011 | 11:41 AM
ahritchie's Avatar
OP, did you have a girdle installed when this happened? Do you use slicks or DR's at the dragstrip? Just curious because my new 383 will be making similar HP through a 6spd and 10 bolt....it does have a brand new Eaton posi and girdle however; I'm wondering if I should even consider DR's (slicks are out of the question now) with this POS rear end and just stick with shitty 315mm sumitomo street tires.
Old Dec 15, 2011 | 12:02 PM
quik95lt1's Avatar
nah thats my secret to run 9.7x's next year.........gotta go get a nice grinder at harbor freight haha
Old Dec 15, 2011 | 12:03 PM
quik95lt1's Avatar
from what you just described DR's will make you the next post like this lol.......actually good track prep and the 315's may do it too lol
Old Dec 15, 2011 | 12:37 PM
  #32
whytryz28's Avatar
Thats what you get for having an M6 lol Go A4 gears tend to last longer
Old Dec 15, 2011 | 01:20 PM
  #33
ahritchie's Avatar
Ouch...looks like I will have a 12 second H/C/I/383 combo then until I can afford a 9" I'm just going to baby the hell out of it and granny shift it; no clutch drops over 2K RPM or decent tires in the near future
I'm still curious if the OP had the girdle or not...who's grenaded a 10 bolt WITH a girdle on it? I know it's a bandaid on a bullet wound but, it can't hurt.
Old Dec 16, 2011 | 01:38 AM
  #34
93Z2871805's Avatar
Veteran: Air Force
I thought you were going to drop in that sweet airfoil and the electric supercharger for the 9.7x times?
I think your 383 and the 6 speed will put some hurt on that 10 bolt if you get some good bite. I'd plan a rear swap in the not-too-distant future man. The girdle may buy you some time, but with the 10 bolt I wouldn't count on it.
Old Dec 16, 2011 | 09:13 AM
  #35
Uwilllosetomy93lt1's Avatar
Bad install from the start....dont take much to blow them even with street tires!!
Old Dec 16, 2011 | 09:24 AM
  #36
speed_demon24's Avatar
Yep they only out lasted 2 differentials and for 8 years.
Old Dec 16, 2011 | 07:06 PM
  #37
pancho toco loco's Avatar
Now that your minus 3 teeth on the pinion what gear ratio you have now?
Old Dec 16, 2011 | 09:20 PM
  #38
My car used to be an automatic. A4's are boring as **** to drive, I almost sold my car because of it.
Old Dec 18, 2011 | 03:13 PM
  #39
Bowtie4life's Avatar
go 4.10's man, I broke a full tooth off of my pinion (richmond 3.73's), and two teeth off of a spider gear, on street tires on the street, and drove 25 miles home on it. Now I have 4.10's and I love them, and I actually hook up better now, except for 1st gear.
Old Dec 19, 2011 | 07:07 PM
  #40
SickSixSpeed's Avatar
im just glad im not the only one who does that. poor 10 bolts
