Engine Problems -- Better Video Added
Old Dec 18, 2011 | 10:02 PM
razorguy's Avatar
I drove it a little ways after the noise started and it didn't change whether the clutch was engaged or not.
Old Dec 19, 2011 | 07:29 AM
quik95lt1's Avatar
yea it sounds like a clutch noise but that doesnt explain the misfiring you were talking about.........get a screwdrive and hold the handle end on you're ear.....use the tip of the driver to touch parts of the engine and see if you can hear the noise clearly.......touch it to the intake manifold.......header tubes.......valve covers.......if you can get the car in the air try the bellhousing and so forth...........
Old Dec 20, 2011 | 11:59 AM
razorguy's Avatar
I'll try to get some time and try that this evening, thanks
Old Dec 23, 2011 | 10:05 AM
razorguy's Avatar
TTT
I'm hopefully going to have time to isolate the problem tomorrow and wanted to see if there were any other recommendations as to where to look for the noise?
Old Dec 24, 2011 | 02:49 PM
razorguy's Avatar
Originally Posted by jaycenk
Remove the belt and Next you got to listen to the water pump and make sure it's not the water pump bearing. If you can rule that out then I would say it's time to move on to looking internally.If the water pump bearing is going bad it could be leaking so look for coolant around where the drive conects and on top of the opti. It could be leaking coolant onto and into the opti causeing the miss.
Wish I would have listened to this sooner! I used the screwdriver trick to listen and as soon as I put it on the water pump it was obviously coming from there. I checked around everywhere else and got nothing. I changed the opti and water pump last spring so the water pump is still under warranty..now I have to decide if I want to do the opti or not. The misfire seems to have gone away and it's revving smooth, but if the bearing is bad and has leaked at all then I might as well go ahead and change it. Blah. Thought I was going to get out of this cheap but it isn't looking good lol
Old Dec 24, 2011 | 02:50 PM
razorguy's Avatar
Thank you for the screwdriver idea, I had no idea you could do it that way. Referring to my above post, as soon as I put the tip of the screwdriver on the water pump it was obvious. Thanks again
