Brakes issues
Old Dec 27, 2011 | 06:31 PM
96azz28's Avatar
Default Brakes issues
So recently i just bought some zr1s for the car and this started to happen the day after i got the wheels. Everytime i wanna slow down i have no preasure i have to push all the way down in orser for it to slw down and ive almost crashed the other day. I havent driven the car since then. What should i do first?
Old Dec 27, 2011 | 07:11 PM
carlos64030's Avatar
Check your brake fluid level and your brake lines for kinks or ruptures for starters.
Old Dec 27, 2011 | 07:25 PM
SS RRR's Avatar
Village Troll
Check your rubber brake lines. Sounds like you may have a leak. Perhaps one of the wheels is making contact on one of the lines.
Old Dec 27, 2011 | 09:00 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Yes, all of the above but it sounds to me like the booster is where to start looking. If you had a line leak, the pedal would drop to the floor with almost no effort. But for Pete's sake, don't drive this car until you find & fix the problem.
Old Dec 27, 2011 | 09:23 PM
96azz28's Avatar
Appreciate the help, ill take a look at it tomorrow since im off..
Old Dec 28, 2011 | 08:07 AM
SS RRR's Avatar
Village Troll
Not necessarily. Depends on the size of the leak, however if it is indeed from the brake line a leak will be obvious enough to spot.
