Which Holes Can Be Plugged
Old Jan 5, 2012 | 12:48 PM
Turnin20s's Avatar
Default Which Holes Can Be Plugged
Looking to clean up my engine bay and was curious if I can plug any of the ports on the water pump
Old Jan 5, 2012 | 12:54 PM
93QWKZEE's Avatar
If you dont have a heater core or are planing on deleting the oil cooler you can plug them all. I used brass freeze plugs look the cleanest IMO. But you can also use rubber plugs with clamps.
Old Jan 5, 2012 | 01:37 PM
shbox's Avatar
As above, it depends on what you want to keep working. You don't say.
Old Jan 5, 2012 | 01:43 PM
Turnin20s's Avatar
Ya sorry, I still have the heater core, but no oil cooler. So I can plug the one on the right side with no issues?
Old Jan 5, 2012 | 02:03 PM
93QWKZEE's Avatar
Yes you can plug it and also the radiator if you had an oil cooler. I have no issues whatsover.
Old Jan 5, 2012 | 03:13 PM
shbox's Avatar
The f-body pump is the only one with that port, anyway. No issues with it closed off.
Old Jan 6, 2012 | 02:39 AM
Turnin20s's Avatar
Thanks guys, just wanted to be sure
