I would use a comp cam 230 intake 236 exhaust at .050 with 1:6 comp pro magnum roller rockers lift.544 intake and .555 exhaust with 112 LDA since you hav an automatic trans you will need a good stall converter .I don,t know what diameter springs that you have but if you have,nt cut the spring seats I would go with comp 918 springs with steel retainers as they only weigh 8 grams and would be very durable.They will go in your heads without machining ,but check your seals for sure.This combo will make about 480+HP flywheel.This is about as big as I would go, a bigger cam will not always make more power, you might gain a little HP at the very top but you,ll lose torque at the RPM that you drive most of the time.This is a pretty big cam for an everyday driver!!I guess you have headers and a good exhaust ,bolt-ons,etc.This combo should make 400rwhp I beleive ,that cam will pull hard to 6000 and rev to 6500 with those 918 springs. You,ll have to tune the computer too! Install at 108 atdc or110atdc if you want more top end power.
