Piston/Valve Clearance
Old Jan 7, 2012 | 11:48 PM
zraffz's Avatar
Default Piston/Valve Clearance
I'm trying to figure out which pistons to get to complete my long block.
I have the 21 degree Trick Flow 185cc heads.
Would a set of pistons designed for the standard 23 degree angle head work?
Basically, can I run these on 21 degree trick flows:
http://www.summitracing.com/parts/MAN-590530-8/
Old Jan 8, 2012 | 12:31 AM
gregrob's Avatar
Yes.. no special considerations piston-wise are needed running TF 21 vs 23 degree heads. Of course pending the cam specs, final ptv will likely need to be measured.
Old Jan 8, 2012 | 01:02 AM
96lt1m6's Avatar
The 21° heads actually give you more PTV clearance per TFS. If you have a stock shortblock you can have 250° duration and less @.050" and 600° or less valve lift before you encounter trouble. Some have done more than 600 but seems too close for me!
