Looking for a new starter, who makes the best?
Old Jan 15, 2012 | 04:25 PM
ReggieWarrenJr's Avatar
Default Looking for a new starter, who makes the best?
Like the title says im looking for a new starter, my engine is around 11.2:1 compression. My stock starter worked fine but I can feel it getting a little weak.
Old Jan 15, 2012 | 06:43 PM
SilverSS07's Avatar
I have a tilton severe duty behind my big block. Been 3 1/2 years with no problems. I had a powermaster mini behind a mild 350 in my s10. Bought it used off CL and had it 5 or 6 years with no issues.
Old Jan 15, 2012 | 06:53 PM
Wyocattech's Avatar
Im running the factory lt4 style starter. Its gear reducted and compact. Thing starts my 12.0:1 very easily with no probs.
http://www.oreillyauto.com/site/c/de...1920&ppt=C0330
Old Jan 15, 2012 | 07:26 PM
Wicked94Z's Avatar
the nippon denso style is the way to go. Powermaster XS (not recommending them) or their look alikes are all modded nippon denso units. Get a jegs or summit brand lookalike and I'm sure it would work great!
Old Jan 16, 2012 | 02:43 PM
JakeSS/Z28's Avatar
iam using a summit starter on my 10.5 383, works flawless.
Old Jan 16, 2012 | 03:39 PM
05HD's Avatar
One thing to look out for on the Denso style starters is the water drain. Most of the "clockable" Chevy versions of this starter have the water drain on the housing blocked shut. This will cause an early demise for the starter compared to a factory install with the water drain fully functional. It is in fact what killed the Denso starter in my IROC. Went to LT4 starters after that and haven't looked back.
Old Jan 16, 2012 | 04:22 PM
96capricemgr's Avatar
Stock starter with upgraded battery cable will handle a LOT more than people assume.
Old Jan 16, 2012 | 11:04 PM
fex77k's Avatar
I went back to a stock starter after my Jegs mini died, it lasted less than a year.
Old Jan 17, 2012 | 10:25 AM
People often blindly assume stock is bad, but the target service life is a LOT longer on stock vs. aftermarket parts.
Old Jan 17, 2012 | 10:32 AM
SS RRR's Avatar
Village Troll
Still have my original starter after 16 years of service nary an issue.
Old Jan 17, 2012 | 10:39 AM
SSickLS1SS's Avatar
i have a powermaster starter, for a ls1, idk if it will bolt up to the lt1 though. shoot me a PM
