Cryogenic Treatment
Old Jan 16, 2012 | 10:11 PM
LTX's Avatar
LTX
Default Cryogenic Treatment
Supposedly some engine builders do this to Strengthen Pistons, Rods, And Crank by nitro freezing them to -300F to modify the micro-structure of the material. Has Anyone done this?
Thanks
http://youtu.be/vPURmV8LHEM
Old Jan 17, 2012 | 04:55 AM
Ballinonabudget's Avatar
Don't they cryo-treat brake rotors to make them stronger? This seems like a pretty cool idea if it truly works, I wonder what the cost is..
Old Jan 17, 2012 | 09:27 AM
nitrous2fast's Avatar
There is a shallow and deep cryo treatments.... most manufactures that do it only do a shallow...
Old Jan 17, 2012 | 09:54 AM
Jerry Clayton's Avatar
We've done it it on several things
300below in Decator , Illinois
And, yes, parts that have been cryoed do machine differently-----------
Old Jan 17, 2012 | 09:55 AM
draggin97s10's Avatar
its been around in engine building for a long time.
Old Jan 17, 2012 | 02:35 PM
Purple Poncho's Avatar
I did it to the guts of my T56. IIRC it makes the metal 15% or 20% stronger.
Old Jan 17, 2012 | 03:13 PM
WS Sick's Avatar
As said it depends upon the degree of depth they cryo it, sometimes machining a part afterward removed the hardened metal. but of course you don't want them to go too deep as it will brittle the part. Chemical hardening is also an option that is used. All your fancy cranks and rods usually have been nitrated to a said depth.
Old Jan 17, 2012 | 04:55 PM
GreenBlood55's Avatar
First thing i thought of was Wesly Snipes being cryo frozen in Demolition Man and getting his frozen head kicked off/shattering. That wouldnt be good for a crank.
Old Jan 18, 2012 | 10:45 PM
stuart4185's Avatar
cryo and thermal coatings. if you have an indy car, its worth a girl hair of horsepower. if you have a street car, its money better spent elsewhere
Old Jan 19, 2012 | 12:24 AM
StraightTimeStirrups's Avatar
Agreed, I had a friend get some high end stereo equipment cryo'd. When he went for the initial meeting the guy gave him a razor blade to try out to see how long it would last. He was still using it 6 months later. Whether its worth the cost for a normal guy, probably not!
Old Jan 19, 2012 | 05:49 AM
Greaseymec's Avatar
I've cryoed key parts of my 4l60e. Seems to holding quite well.
Mec
Old Jan 19, 2012 | 09:16 PM
killerz97's Avatar
Has anybody seen a noticeable difference in strength? Maybe Jerry could chime in since he has some first hand experience?
Old Jan 19, 2012 | 10:05 PM
1badzee's Avatar
If there is really such a significant benefit in strength, the prices are damn well worth it IMO, especially for someone looking for a bit of additional strength without breaking the bank. Was quoted $130 to do a crank, $7.50 per connecting rod and about $340 for a bare block.
Old Jan 19, 2012 | 10:49 PM
1963SS's Avatar
There's a great article about cryo treatments in the last issue of engine professional magazine. Every thing you ever wanted to know.....and maybe more. I'm personally sold on the use of it for some key stressed components. Try this link and start reading on page 48....I think. It's the whole mag online. Just check in the index if page 48 isn't right.
http://www.aera.org/ep/EPQ4-2011/index.html
Old Jan 20, 2012 | 02:01 PM
LTX's Avatar
LTX
Great info!!
Thanks
Old Jan 20, 2012 | 02:16 PM
1963SS's Avatar
Great info!!
Thanks
Not a problem. Even us old farts have to keep up with modern technology. The Opti ain't your Daddy's distributor.
Old Jan 22, 2012 | 03:25 PM
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
been doin' that for 10 years! (as require of course). I believe that has has helped my trans survive a bit longer
Old Jan 22, 2012 | 04:31 PM
Wicked94Z's Avatar
why are you running titanium valves and shaft rockers with a gm847 cam? that makes no sense
