LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   This MSD unit is pretty solid. Let's see how it holds up. (https://ls1tech.com/forums/lt1-lt4-modifications/1506095-msd-unit-pretty-solid-lets-see-how-holds-up.html)
Rob94hawk Jan 17, 2012 07:25 PM
Just got this in from Summit today. Let's hope it lasts longer than the POS new Delco unit. The quality looks nice from the exterior. I hope it's guts work better than it looks. Wish me luck.
http://img.photobucket.com/albums/v222/robkoz/MSD.jpg
OlMastaScrilla Jan 17, 2012 07:28 PM
Good luck! looks like a very nice peice, also curious to see if this is worth the extra bones.
stevo9389 Jan 17, 2012 07:32 PM
the bolts to mount it liked to back out on me. the stock ones managed to stay put.
shbox Jan 17, 2012 07:56 PM
I hope it does well for you. The Delco units have at least as good, if not better, track record. It's not all about looks. Be careful of the timing screw. If it is or gets out of whack your timing will be skewed and there is no real way to tell where it is. Some have had trouble with the screw not acting correctly.
95LTXZ28 Jan 17, 2012 08:01 PM
^^what he said, also still take the unit apart and loc Tite the rotor screws!!
FocusVince Jan 17, 2012 08:04 PM
That's pretty nifty, it sure is purtty
Rob94hawk Jan 17, 2012 08:19 PM
I'm not messing with the timing screw. According to MSD it already has loctite on it.
I was told the rotor screws now have bolts.
shbox Jan 17, 2012 10:00 PM
Yeah, ok, just making sure you know what is what. Most probably don't have a problem with it, but some have been gimped up from the factory, so just be aware. Better to have more info than what you might need. :) I'd feel better about the MSD if they had left that "feature" off.
fex77k Jan 18, 2012 12:23 AM
Yes the first unit I bought in 09 didn't have any lock tite on it, after I sent it back it did. I have another one and it had it on from the factory.
camar0corey Jan 18, 2012 07:17 AM
I had no issues with my MSD opti, and I had one of the earliest units. It had just come out when I happened to need an opti, good timing I guess!
96capricemgr Jan 18, 2012 10:02 AM
Way are you basing the below statement on?
Rob94hawk Jan 18, 2012 12:19 PM
All your base belong to us?
Zlow28 Jan 18, 2012 01:30 PM
Originally Posted by Rob94hawk (Post 15854973)
All your base are belong to us?
Fixed!
But i havent heard anything bad about the msd distributer. Only that its more expensive than an oem replacement. However i bought an ac delco.
RamAir95TA Jan 18, 2012 01:38 PM
More expensive, less reliable, and provides zero benefit over an OEM AC Delco? I'll pass!
ACD FTW.
pillarpod Jan 18, 2012 02:41 PM
Originally Posted by RamAir95TA (Post 15855277)
less reliable
in what way is it less reliable?
R3DLT1 Jan 18, 2012 03:04 PM
ACD FTW.
Its red!
:engarde:
Rob94hawk Jan 18, 2012 03:29 PM
It's not. They all suck. What day doesn't go by where you read about someone's opti taking a dump on any of these forums? I went with MSD because I need to be able to point the finger at someone if their "high quality" product takes a crap earlier than it should. Believe me, someone will pay.
BTW, the opti adapter that I got from EFI Connections brand new, was completely corroded. I like the fact that the MSD unit comes with one built in. Not that it's a guarrantee but it goes to show you that anything brand new can crap out.
My "new" AC Delco opti is proof of that.
BTC Jan 18, 2012 03:41 PM
My factory installed optispark lasted over 100K. It was an AC/Delco.
3DFORMULA Jan 18, 2012 03:55 PM
Take it apart and verify.
96capricemgr Jan 18, 2012 04:30 PM
A LOT of "opti problems" are caused by incompetence on the part of the person diagnosing or installing them. The opti is BLINDLY bashed and any hiccup is seen as a complete failure.
It also is pretty badly neglected, nobody would ever think of leaving an HEI cap and rotor unchanged for 100K and if they did they wouldn't blame the HEI they would admit it just wore out.
A lot of the heavy hitters tried the MSD when it first came out and a LOT of them went back to stock because it is better, some of them might do things like pop rivet the rotor or something but at any rate you find a lot of stock optis on fast cars doing well and a lot of "failed" optis on cars like your's.
Stock opti is not perfect but it is a whole hell of a lot better than the newbs are lead to believe by the ignorant masses.
© 2026 MH Sub I, LLC dba Internet Brands
