please help! 2 questions heater and tps
1. I have a 94 z28 LT1. all the exterior is converted to a 2000 ss tho..but my question is my heater isn't working idk why it hasn't since I got the car...it blows air but not hot...well when I switch the selector for face floor ect it makes a psssssss would like its depressurising..is that normal? would that be the rradon my heater doesn't work?
2. the car has been acting up lately while shifting...it erraticly shifts and sometimes doesn't shift to 4th..I have an automatic...now I have been looking around the forum and it seems to be the tps...does anyone know the location?
thanks in advance
2. tps is on the passanger side of your throttle body. connected with 2 screws. looks like a roundish shaped disc.
do a coolant presure check to make sure it would be the easiest way to find if anything is leaking. like heater hoses and heater core.
does the heater hoses get warm under the hood? there is two hoses that go into the firewall for the heater core
does any coolant leak out onto the ground from the firewall inside the engine bay? ( you have a drain on the heater box incase the heater core leaks that sticks out of the firewall and drains)
and there is a trap door for the ac core and heater core. in the heater box can you hear that move under the dash? if that dont move you wont get heat eather. ( switch it from hot to cold and you should hear it)
and a good way to check for the heater core to be cloged is to take both heater hoses off from under the hood and blow air threw one and go through the heater core then it should come out of the other hose.
like i said i feel the heat thats supposto be inside blowing back out of the firewall where the hoses are...and when i turn the heat off nothing is blowing back (obviously)
