terrible idle and stalling
-engine load 4%
-coolant temp 174*
-short term fuel trims, both banks 0-2% average and fluctuating up and down a few points
-long term fuel trims, both banks fluctuating up and down from about -9 to +8%
-map sensor reading 10inHg steady
-12* timing advance but moving up and down
-IAT 92* (kinda warm in sc!)
-Maf 1lb/min and when I raise the rpm and hold it steady about 2500rpm it will read about 2lb/min
-upstream o2 sensors both banks .005-.795 and fluctuating drastically!
-tps sensor reading 0% and will rise if I increase the throttle.
I unplugged both of them afterwards and the car was not any better, so I unplugged the MAF again (after I shut the car off) and fired it back up still no better. WTF?
So it seems I have ruled out the MAP, MAF, TPS, and engine temp sensor.
Now there is something that seems odd to me, while the car is trying to idle I think I can hear the IAC trying to control the idle and I can hear hissing when the engine starts to stall. So thats what I have......any thoughts?
It's hard to make a call at this point. Nothing you've listed really helps narrow it down. This is when I'd start pulling all the plugs, keeping them in order for inspection -- you need to find out what cylinder(s) are having issues. If you don't find a specific cylinder having trouble, then look for things further back that can cause a random misfire (ignition coil/module, optispark, possibility of a shoddy Walbro pump or electrical connection). Make sure all of the fuel injector electrical connectors are on good and tight.
Anyway, here's another book for you:
(1) You'll have to be more precise on the LTFTs. They shouldn't be "fluctuating" very quickly -- the trends should be relatively stable. Don't mess with the throttle, just read both banks at idle and post their respective percentages. (Different load/throttle conditions will jump the LTFTs into different memory cells, and that isn't very helpful here -- we just want to compare left/right bank LTFTs at idle only).
We're trying to find out if one bank is running richer or leaner than the other at idle. At first glance, those percentages translate to BLM counts between 116~138, but you didn't cite their respective banks. For reference, they bottom out at 108 (computer subtracting about -15% fuel for a perceived rich running condition) and max out at 160 (computer adding about +25% fuel for a perceived lean running condition). Your target air/fuel ratio is being corrected back to normal 14.7:1 between that range -- but outside that range, the computer can't correct for it, and you'll have a physical rich or lean running condition. The trends help us know what's going on and locate problems, because both banks should be identical.
(2) Spark timing seems low to me. Might be the computer pulling timing due to perceived knocking from the rough running condition. You said earlier that it's backfiring -- did you mean out the intake (a technical "backfire"), or just popping noises in the exhaust (unburnt fuel igniting in the exhaust)? Any excessive 'clacking' noises coming from underneath the valvecovers?
(3) 1 lb/min MAF reading translates to about 7.56gps. Fairly normal. Based on the fact that it runs the same with it connected or disconnected (speed density mode), I'll assume for now that the MAF is not the cause.
(4) You said you disabled EGR? What about EVAP? How exactly did you go about doing that? Just a wild guess, but if you're hearing hissing noises only when the engine stalls, perhaps you left one of the EVAP or EGR control solenoids' electrical connectors connected and vacuum ports open? That would, in effect, create a vacuum leak only when the computer called for those systems to activate, triggering the solenoids to open. If you haven't already, be sure to disconnect their respective solenoid electrical connectors (which will probably throw a diagnostic trouble code / SES light) and cap everything off.
(5) Probably should have asked this first, but did you do ANY other work to the car (aside from the fuel pump) prior to this rough running condition? Or did it just happen out of the blue? It's always a good place to start looking at anything you've messed with recently. Get back to us on those fuel pressures.
Check for burnt spark plug wires -- pop the hood at night and look for any blue arcs of light.
I deleted egr when I done the headers years ago, not the evap to my knowledge.
Now to the backfires, the car will backfire in the exhaust when I let off the gas (6 speed with clutch out and in gear). When the car stalls most of the time it will backfire through the intake. The only previous work was that I changed out the opti harness because it had a broken clip and would back out not allowing the car to start. Ran when when I installed that. Then the fuel pump quit on me. The fuel pressure seems fine with 42psi at idle. I will remove plugs tomorrow I guess when I get off work. Oh yea plugs and wires in good shape fairly new and not arching.
-Does the fuel pressure rise above 42psi when you disconnect the vacuum control hose? If not, the regulator is faulty. Finding that delta pressure change is a major component to testing fuel pressure -- you're not done testing yet.
-Do you see the difference between saying, "the LTFTs are maybe sorta +/- 5% to 9%" versus saying "The left bank fuel trims are -5%, and the right bank fuel trims are +9%"?
The former means nothing. The latter tells me precisely what is happening -- it tells me your left bank is running rich, and your right bank is running lean. It tells me your right bank would more likely have a slight misfire, as that would produce excess oxygen on that bank to be picked up by the oxygen sensor, and the computer is adding fuel to compensate. Even a few percentage points might help us find out where to look.
Anyway, I think I'm done here -- I'll let someone else step in. My best guess at this point is an ignition-related misfire. Clean and inspect that new Optispark harness, and perhaps check continuity between the opti harness to the computer with a digital multimeter. I'd personally ditch those Bosch oxygen sensors regardless -- get AC Delco.
Good luck -- hope you get it figured out soon.
Might as well try doing it yourself and save yourself some cash, unfortunately opti replacement is a fact of life if you own a LT1 car long enough. The Best V8 Stories One Small Block at Time
