Line Loc Not Working
Old Jan 25, 2012 | 08:57 PM
chevylt1camaro's Avatar
Default Line Loc Not Working
i have a Hurt Shifter Line Loc that is not workin i do believe it engages unsure though any suggestions?
Old Jan 25, 2012 | 09:06 PM
lt1slowz28's Avatar
turn on line lock, push pedal to floor, hold button, release pedal...
if not check the wiring.
Old Jan 25, 2012 | 09:16 PM
ok then i have it wired wrong the instalation instructions are a bit confusing, i have a push button that is an on off switch which i believe to be the button to " Turn On" the Line loc then there is an actuall button like device that is not mentioned in the instructions. where would i wire that into?
Old Jan 25, 2012 | 10:03 PM
think i got it figured out will try the new setup tomorrow
Old Jan 25, 2012 | 10:42 PM
lt1slowz28's Avatar
you wire the on off toggle inline closer to the solenoid than the button, so when it is off the button will do nothing.
Old Jan 26, 2012 | 05:36 PM
got it working thanks
