LT1 Build suggestions/help
Down
Down
lol
RamAir95 has a 383; not a 350/355....I don't see it happening on a typical 350/355 build.....prove me wrong! my old 355 used to run 11.4x's at 120+mph .....was a stock bottom end with 11.2:1, TFS Untouched 195cc heads, an AI 234/242 HR cam and a ported LT1 intake.......shifted at 6800........never got a real reading but with another 35+ of cfm head flow i can almost guarantee that motor wouldve made 450rwhp with a stick shift even with mild compression....
PMs replied
Down
...Ai did a 355 with 480 RWHP
....looks like a far from typical setup however....I would consider a 450rwhp 355 the exception; not the norm....would be much easier to hit that goal with a stroker. http://advancedinduction.com/Results/AiResultsAleks.php
....looks like a far from typical setup however....I would consider a 450rwhp 355 the exception; not the norm....would be much easier to hit that goal with a stoker. http://advancedinduction.com/Results/AiResultsAleks.php
told ya
im confident a moderate compression AI 200cnc headed, decently cammed 355 will do it all day long.....
you'll be seeing a build thread this weekend of the 383 im doing for another board member.......will make well over 700 on nitrous
My 350 with AI's 200cc LT1 heads and their 228 cam puts down 425 SAE at 6400 rpm through an A4. You think picking a cam to peak 500 rpm higher and running it through a manual trans won't pick up 25 hp? Come on!
