Need help with 97 Z28
Old Feb 1, 2012 | 04:21 AM
Crazyace85's Avatar
Default Need help with 97 Z28
I have an internal squeak/chirp. I've pulled the belt and ran the car and squeak is still present. I tried the screwdriver test and the noise is loudest at the top rear of the intake. The noise starts as soon as the engine starts and doesn't quit.
Does anyone have a suggestion?
Old Feb 1, 2012 | 04:03 PM
BackInBlack02's Avatar
Do you have A4 or M6? it may be the trans, just a thought.
Old Feb 1, 2012 | 11:39 PM
Crazyace85's Avatar
Trans is a 4L60E.
The noise starts as soon as I fire it up sitting still. Is it possible to be the trans while not moving if so how can I check it other than pulling the trans.
Old Feb 2, 2012 | 10:37 AM
stuart4185's Avatar
well the EGR and fuel pressure regulator are back there, check the vacuum lines for rotting, or the egr for bad gaskets or check the torque on the intake bolts
Old Feb 2, 2012 | 11:09 AM
RamAir95TA's Avatar
Post up a video of the noise.
Old Feb 6, 2012 | 12:45 PM
Crazyace85's Avatar
As soon as I get a day off I'll post up a video.
Old Feb 6, 2012 | 10:23 PM
jaycenk's Avatar
Could unbolt the converter and push it back if it's none of the stuff above.
