Building a LT1 for a turbo. HELP
Old Mar 18, 2004 | 09:19 PM
Blown96SS's Avatar
Question Building a LT1 for a turbo. HELP
If I am planning on putting a turbo on it, What internals do you suggest and money is no object????
Old Mar 18, 2004 | 09:34 PM
Vendetta's Avatar
If money is no object, go with some sub 9:1 JE or Ross pistons, some H-beam rods, and a 4340 crank. How much boost are you planning on runnin?
Old Mar 18, 2004 | 09:42 PM
Blown96SS's Avatar
i am planning on running about 15-20 lbs.
Old Mar 19, 2004 | 07:58 AM
Fastbird93's Avatar
Definitely need some forged internals. An 8.5-9.0:1 static compression ratio should be ok for that amount of boost.
If money is no object, I'd be looking at doing a 383 with a Callies Racemaster 3.750 crank, Oliver Billet or forged 6" H-Beam rods, and some good JE or SRP pistons. Splayed 4 bolt mains, studs for the main caps and heads.
But that's just what I'd do.
Old Mar 20, 2004 | 07:55 PM
bowtie9696's Avatar
I'd definetly get some 4 bolt caps, a good cam, hardened pushrods, heavy duty timing chain, and if you plan on going with more boost in the future, o-ring the block. You also probably want a deeper oil pan with more capacity. Just what I can think of right now.
