AC delete panel
Old Feb 16, 2012 | 07:54 PM
fastredlt1's Avatar
Default AC delete panel
I know this is a stupid question! When you install a BMR AC delete panel, doe's it get installed in the engine bay or inside the car behind the dash?
Old Feb 16, 2012 | 08:48 PM
fex77k's Avatar
It goes on the engine bay side.
Edit: if you want to keep your heat it would be easier to do it from the engine bay side.
Old Feb 17, 2012 | 12:42 PM
cucui's Avatar
I’ve seen it on both sides; I already had my engine pulled out so I put it on the engine bay side.
Old Feb 17, 2012 | 06:26 PM
fastredlt1's Avatar
I called BMR today and I was told that it gets installed from in the car. But I agree with you that it can go both ways.
Old Feb 17, 2012 | 07:09 PM
BIGCAT7274's Avatar
i made my own. installed it on the inside. you can also cut the foam seal off the ac box and reglue it to the delete panel.
