Please explain this picture
If things dont look good, then we'll build a motor on the side and put it in when this thing goes.
If things dont look good, then we'll build a motor on the side and put it in when this thing goes.This is a vital part for engine longevity because GM spent X amount of dollars to put it on the engine. If it were really not needed, it would not have come on the engine from GM.
I suggest that the OP keep it as is or simply remove the piggyback pulley and use the OEM piece. If he is still wanting to reduce mass and still have the functionality of the crank dampener, then look into the ASP underdrive dampener which is much lighter than stock and much cleaner in appearance.
Above all I think there are very little gains to be had by using either type of underdrive pulley or dampener.
It does depend on your driving habits. If you drive in stop/go conditions where there is not enough voltage to properly charge the battery then the battery is going to eventually ******* die. M6 cars did not have a battery ******* dying problem as much as the autos had a battery ******* dying problem.
