Water pump or just the gasket?
Old Feb 22, 2012 | 04:11 PM
Camaro_ZL2's Avatar
Default Water pump or just the gasket?
okay i had my car sitting for acouple months i go out side to turn it on and seems like like its shooting a mist of water up from where the water pump just looks like a small leak do i have to change the entire water pump or just the gasket?
Old Feb 22, 2012 | 04:34 PM
93 LT1 Vette's Avatar
since the pump has to come off to change the gasket, it could be the weep hole on the back of the pump. Inspect the pump after removal and then make a determination. I know I waited just a week and it killed my Opti. A 100 bucks quickly became 700.00. Just MHO.
Old Feb 22, 2012 | 04:40 PM
shbox's Avatar
If it is shooting a mist, I would suspect a pinhole leak in a hose or a loose hose clamp. I would inspect more carefully before doing anything drastic.
Old Feb 22, 2012 | 04:43 PM
96capricemgr's Avatar
I have never seen an LT1 waterpump gasket fail.
As shbox said I would look at hoses.
Old Feb 23, 2012 | 12:47 AM
Camaro_ZL2's Avatar
thanks guys its at the body shop right now so ill take a look at it as soon as it is back here or before i bring it home
Old Feb 23, 2012 | 02:16 AM
food nd cars's Avatar
+1 on the hoses, had a similar problem and just wrapped the small hole and put a clamp over it. Been fine for over a yr now
Old Feb 23, 2012 | 06:55 AM
mab6680's Avatar
i had a faulty rad cap that didnt open and it blew the water pump gasket and let me tell you it was dumping coolent got lucky tho didnt get the opti wet you can get a ac delco pump on rockauto for $103
