No engine crank
Old Feb 23, 2012 | 10:56 AM
matthoef's Avatar
Default No engine crank
Ok, I drove my 1996 Z28 to work this morning ... had to drive to a meeting and then when I get back out it doesn't start. It "turned over" for about a second and then a thud. After the thud, nothing ... not even an attempt to turn over. Checked the belts and looked under the car for obvious problems ... nothing. I'm leaned towards the starter, but I'm still learning about the LT motor so I'm not sure if there's something else I should be looking for. Advise please! I greatly appreciate any help/insight given.
Old Feb 23, 2012 | 11:18 AM
blk3rdgen91's Avatar
Could be your starter..is it manual then try and push start it to get you home
Old Feb 23, 2012 | 02:20 PM
matthoef's Avatar
Yep ... It's a stick. I'll give that a try, didn't even think about trying that.
