Need stall help with this cam
Any help and suggestions is appreciated
Thanks Calvin
Im gona say 4k. I went with a 3800 when my car was stock and wished id went bigger. Why suck small cam for a stroker tho?
I read as much as I could about the 3600, but I thought that cam was big enough should I have went bigger I went with what I thought would be mainly street-able (sleeper) , what cam would you suggest ? I was advised by Erson that with that cam I would be looking at high 300 low 400 in HP so thats why I chose this cam.
3.25" thick axle tubes
Heavy Duty large truck bearings
31-spline axles
Can't really ask for more at this price. Oh and you will need a conversion u joint and possibly may need to shorten the Novas driveshaft..
Due to the rpm range thing why don't you tell us what springs they spec'd because they can get that wrong if they assume too low an rpm range.
Then the stall thing I would say is antiquated 3 speed non-lockup thinking. These days with the 4L60E a LOT of guys with stock cammed Caprices are daily driving 28-3200 9.5" converters. Of course if you are going to do this wrong and put a 12" converter in it then stay about 2400 as good 12" don't really go any higher.
It really is a little worrysome that you didn't mention the heads, please tell us you had them ported.
I haven't had them ported yet but that can still be done, but they are the stock aluminum heads which should flow pretty good from what I understand.
The ported heads/cam 350 made 425rwhp the 383 made 455rwhp and Erson is telling you maybe 400fwhp does this put into perspective just how bad a decision it would be to put together a motor with as cast heads?
Long as you got so much other bad advise on your build let's ask about the crank. Please tell us it is forged and balanced by the machineshop.
with a small block. If the stock big block cars are 70s stuff you will probably cover them without porting the heads BUT the average heads/cam LT1 car will walk you like you hit the wrong pedal.
I have run against stroker cars that cheaped out or fell for marketing hype on heads and left them feeling a little bitter about the situation.
