Part number please!!
Old Mar 1, 2012 | 04:35 AM
MidwestTA's Avatar
Default Part number please!!
I need the part number for the coolant temp sensor that is in the water pump housing, 93 trans am. I found a few differant ones online... just want to make sure I get the correct one.
Old Mar 1, 2012 | 04:46 AM
93Z2871805's Avatar
Veteran: Air Force
Iirc, the one in the pump is for the PCM and the one in the head is the gauge. http://shbox.com/1/Parts.htm
Old Mar 1, 2012 | 04:52 AM
MidwestTA's Avatar
Sweet link, I forgot about that site. It is the one that sends signal to the pcm that I need, My fans come on about 10 seconds after the car is started.
Old Mar 1, 2012 | 04:58 AM
93Z2871805's Avatar
Veteran: Air Force
shbox has been a great help to pretty much every LTX owner at some point in time.
Old Mar 1, 2012 | 05:00 AM
MidwestTA's Avatar
Thanks for the help man! Hopefully I can get this thing up and on the road by April, I am sick of my gutless saturn lol.
Old Mar 1, 2012 | 06:36 AM
shbox's Avatar
Fans come on when there is a check engine light. Is yours on? If so, you need to retrieve any trouble codes. Your 93 does not need a scanner to do this.
Old Mar 1, 2012 | 01:08 PM
MidwestTA's Avatar
I thought it was the other way around LOL. The fans come on, and and the check engine light comes on, I thought it was coming on because they where turning on when the car was still cold. I'll have to check the codes with the jumper wire. Thank you very much!
