double checking on 93 timing chain
Old Mar 4, 2012 | 09:34 PM
TSAEB's Avatar
Default double checking on 93 timing chain
so i see that my 93 lt1 is limited to these oem replacement timing chains gm, cloyes or Lunati 93094. I didnt see the part number to the cloyes. however after reading even if i decide to swap to a 95 vented opti. A single roller seems to be fine. Or atleast i havent seen someone post a broken single chain or issues with it. am i right? off?
im shooting for 450 na with 200 shot, under 7k rpm.
Old Mar 5, 2012 | 05:22 AM
bowtiedad_z28's Avatar
Greg if your staying with oem the cloyes part number for the complete set is CLO-C-3228. That is what i just put in mine, purchased from Summit.
Old Mar 5, 2012 | 07:32 AM
Jpack's Avatar
If you want to save a few bucks, I think I have at least two splined cam gears laying around you can have, just pay for shipping. Then you can just get a chain and crank gear. Hell I may even have those laying around as well.
Old Mar 5, 2012 | 07:55 AM
TSAEB's Avatar
thanks guys. also had moe bailey say i would be fine. so oem it is.
yeah jpack let me know.
