help a noob out
ngk tr5's (yes i have two boxes)
my question is do i need to gap them or can i just put them in right out of the box?
also i heard the lt1 is a huge pita to do this can anyone point me in the direction of a write up or diagram or really anything helpful?
And yes they are a pain the *** for sure. you'll be bleeding most likely when you are done. I've never done them with the stock manifolds though, I had my Longtubes when I changed mine the first time. I made a custom socket to get to some of them, I just took a regular plug socket and cut it down to 1/3 its size, hollowed out the square hole and slid it onto the plugs and used a ratchet wrench. It's also easier to do this under the car rather than on top.
Pass.. side
Remove alternator to gain access to #2 plug
Drivers side
Does not pose to be a challenge
This response gives me hope but some searching i did made it sound like a huge pita, removing part after part...
I remember cylinder 4 being a PITA because of that EGR pipe that wraps around under the engine as well. Your arms are going to be pretty cut up, but you'll feel like a badass. Good luck.
