Single plane question.
They aren't completely neccesary as long as you're using good intake gaskets and the heads havent been flat milled too much, but if you could get them to fit I would use them.
The org owner did not do a good job with this intake if they were on stock LT1 heads. I had to do a lot of mods to get it to fit and the center bolts were never drilled so that sucked.
Anyone boost a intake with only the outer 8? Plan to push around 700rwhp
